with that injector dumping so much fuel you could very well have contaminated oil and you'll be worrying about alot more than a dead cylinder. Seems like the injector is stuck open. Leave the problematic injector disconnected as well as all the others. Pull the spark plug to that cylinder and roll the engine a few times to see if fuel is still spraying into the chamber. If so this means that the injector is open and fuel pressure alone is free flowing gas into the engine.
"torque gets you off the line...& hp gets you over the line." - TTKeeper |
